Easy Way to Remove Plastic Covers on Rocker Panels?
Old Jul 27, 2018 | 04:56 PM
Disco1inOxford's Avatar
Default Easy Way to Remove Plastic Covers on Rocker Panels?
Hi Folks
New to the forum, and couldn't locate a thread on this.
I want to remove the plastic covers above the running boards on my 99 Disco. It looks like rust is starting there and I plan to wire brush and apply por-15. What is the easiest way to remove these? I see that plugs in the bottom of the door jambs, but wow these are stuck in good? Who has done this? Any thoughts?
Thanks!
Old Jul 27, 2018 | 05:25 PM
OverRover's Avatar
There is NOTHING fun about removing these bits, especially if the metal holding the plastic rivet (#79086L) is rusted.
The rockers tend to just crumble.
You can try a blunt punch to get the rivets out, but 9 out of 10 times I just drill them out.
A sharp drill bit and high speed is your friend here.
Go easy, follow the instructions, start drinking/swearing... and you'll get it done. GOOD LUCK!
Here is a link with some pics of the fun you will be facing once the sill covers are removed.
> https://www.landyzone.co.uk/land-rov...cement.103369/
Old Jul 27, 2018 | 06:14 PM
robertf's Avatar
wear gloves. that fiberglass is nasty
Old Jul 27, 2018 | 06:21 PM
Thanks for all of the feedback! That looks like the spot but the plugs are a little different, they are not rivets unless I am missing something? Here a couple of photos. Is this thing can be a pain to get back on once I get if off?
You can see the rusty hole where I removed this one.
Old Jul 27, 2018 | 06:29 PM
Thanks! It does look different what I removed seemed to be a plastic plug not a rivet. Is this going to be a pain to get back on again too? Where is there fiberglass.
I will try and upload a couple of pics
thanks again
Old Jul 27, 2018 | 06:32 PM
This is the plug I pulled out of the rusty hole on the right.
Old Jul 28, 2018 | 11:11 AM
OverRover's Avatar
The short answer is YES because you are not doing STEP 3 and punching/drilling the center spreader insert (the square flat bit in the pic below) through the rivet.
The rivet is STILL EXPANDED...… You are making more work for yourself for sure trying to remove it like this!
If you are just using a panel popper tool to remove the rivet when it's still expanded you are going to enlarge the mounting hole.
Using "force" to pull the expanded rivet through rusty metal =
And if you don't like the rivet style sill fasteners then there are other types. Have at it and good luck!
Old Aug 1, 2018 | 11:41 AM
Paul Grant's Avatar
If you haven't already gotten there, it's true joy removing the 10mm nuts and bolts that secure the front of these rockers to the fenders.
Old Aug 1, 2018 | 11:45 AM
Yup, those things are rusted on there. I realized this was a job that I needed to dedicate much more time to. I carefully treated the lower rear part of the rocker panels with Por-15 while not entirely removing the covers. The rust didn't seem nearly as bad as I had thought. I appreciate all of the feedback, very helpful and help me avoid making a real mess of things!
Old Aug 2, 2018 | 06:30 AM
Paul Grant's Avatar
Waxoyl is great for inside the sills.
Will_2018
May 11, 2019 10:53 PM
pottzie
Jul 17, 2012 11:34 AM
graveshaker
Oct 17, 2010 08:25 PM
Disco2Guy
Jan 21, 2008 01:41 AM
evillama
Mar 15, 2006 01:42 AM
