Engine ticking
Old Mar 30, 2012 | 09:55 PM
  #21
ColoDisco's Avatar
I agree. It was a hail Mary that did not work. Even though, tick before and tick after. How are the tappets filled with oil?
Old Mar 30, 2012 | 10:10 PM
  #22
Ok, I misunderstood, I thought you added the Lucas with the last oil change and then the tick started shortly after.
Hydraulic tappet - Wikipedia, the free encyclopedia
Old Mar 30, 2012 | 10:51 PM
  #23
ColoDisco's Avatar
Oh sure! Break out Wikipedia!
I am just worried that the oil to the failed lifter is blocked. I think I still need to check my oil pressure just in case.
Old Mar 31, 2012 | 03:58 AM
  #24
Chris-bob's Avatar
Yeah, it's sounding like a collapsed lifter. With that gunk, could be a blocked passage keeping oil from the lifter. You're going to need lots of tiki torches and scantily clad women for this repair...
Old Mar 31, 2012 | 07:39 AM
  #25
Jake1996D1's Avatar
2 questions
What did the bottom of the tappets look like
What color was the lobes on the cam
Old Mar 31, 2012 | 07:40 AM
  #26
See this from shop manual - may provide additional enlightenment if read from the glow of the tiki torches held by the scantily clad women.
File Type: pdf
Old Mar 31, 2012 | 08:34 AM
  #27
XCELLER8's Avatar
COLO: I too chased a "tick" for a few weeks....went the whole route of gaskets, oil, bs additives, flush etc, etc, the problem ended up being a loose insert in a couple of the rocker arms. The r/a is made of alluminum and the conical inserts that contact the push rods are steel..AND they are barely held in the r/a by some sort of staking process. In my case there was no noise with a cold engine but as things warmed up the tick would get louder....to isolate this I had to run the engine with the valve covers off ( NO you wont throw oil everywhere) it's much easier to isolate WHICH rocker(s) is making the noise. I found that 2 or 3 of them had loose inserts, a few new rockers and the tick was gone. I know that this may not be your issue but it sure sounds like mine did....it's worth a look
Old Mar 31, 2012 | 08:57 AM
  #28
oilspotLR's Avatar
Originally Posted by ColoDisco
Has anyone used that kit on a disco? I only ask as I bought the coolant pressure test kit and it did not have the right adapter for my disco.
I have one. I had to buy an adapter to get it to fit. It WILL NOT fit into the OIL Pressure Sending unit at least on the 3.9L. I bought a glow shift oil sandwich adapter, it goes in between the oil filter and engine.
Originally Posted by pinkytoe69
I used it on mine. The adapter in the kit that fits the port on the disco is a teensy bit too small. However getting it nice and snug, but not over tight, everything worked ok.
REALLY? How did you get that to work? It goes nice for few turns but doesn't get snug enough to not blow oil like crazy everywhere...-my experience
Old Mar 31, 2012 | 09:01 AM
  #29
oilspotLR's Avatar
Looking to get some advice. Sounds like tappets or ??
It is only on the passenger side. Sounds like it is towards the back of the engine.
1995 discovery engine noise - YouTube
I would say it is on the passenger side. Make sure, if you replace the tappets, that you do all of them. Do the CAM and pushrods as well. Don't fail like me and do only the tappets, only to 500 miles later have the same tick like you. My engine sounds like yours when yours idles. The noise actually goes away after RPMs are increased. I personally think it would be easier to get a used one, and put that guy in considering mine is at 180XXXMiles Its your decision.
Old Mar 31, 2012 | 09:43 AM
  #30
slanginsanjuan's Avatar
This sounds exactly like my tick. Especially the sounds good until it warms up. I'm gonna check this immediately. Is this the rocker arm you mean:
