Engine ticking
Old Mar 31, 2012 | 01:56 PM
  #31
pinkytoe69's Avatar
Originally Posted by oilspotLR
REALLY? How did you get that to work? It goes nice for few turns but doesn't get snug enough to not blow oil like crazy everywhere...-my experience
I dunno? I just kept going until it felt tight. I think if you use DannyLees suggestion of a couple wraps of teflon tape it would be plenty good.
Old Mar 31, 2012 | 01:58 PM
  #32
XCELLER8's Avatar
Originally Posted by slanginsanjuan
This sounds exactly like my tick. Especially the sounds good until it warms up. I'm gonna check this immediately. Is this the rocker arm you mean:
yes !!!
and if that ends up being a(the) problem....remember when you order that there are LH and RH of these, (4LH & 4RH on each side) , also.... to add to the a$$ache you may pinpoint one or two, and by the time you get the rockershaft out of the head....the alluminum rocker may have cooled off enough and shrunk enough to make it hard to find the rattler.....just re-heat the suspected rocker with a heat gun or a 100watt bulb and it should loosen up the culprit enough to find it. They used to make solid steel rocker arms for these, maybe someone still has them.
Old Mar 31, 2012 | 04:58 PM
  #33
Danny Lee 97 Disco's Avatar
Going to take lots of firewood, firewater, and wild critters to take care of that clatter.
Old Mar 31, 2012 | 05:14 PM
  #34
ColoDisco's Avatar
Mine is there warm or cold. I can get a complete set of tappets for $140.
Old Mar 31, 2012 | 05:31 PM
  #35
slanginsanjuan's Avatar
Originally Posted by XCELLER8
yes !!!
that's a bitch cause I can't be ordering one at a time. gonna check it with my guy and see what I can do. maybe i should order the new set with the concept one's failin' then the others are gonna follow.....need to figure that out.
Old Mar 31, 2012 | 06:20 PM
  #36
oilspotLR's Avatar
Default Your lucky!
Man you are lucky!!! hahahah
Old Apr 1, 2012 | 10:32 AM
  #37
Jake1996D1's Avatar
Replace the cam too. If you're a tech you already know that
Old Apr 1, 2012 | 03:24 PM
  #38
so order a cam and a few of those rocker arms....hmmm list is growing.
Old Apr 1, 2012 | 03:28 PM
  #39
Jake1996D1's Avatar
If you're gonna do tappets you should always do cam. I'd do a compression test to see if the piston rings are sealing cylinder if not.... You might was well do the whole damn thing.
Get a crower cam if you get one they are hundreds cheaper than a genuine land rover cam.
Or just live with it. It will probably last a long time fine.
Old Apr 1, 2012 | 04:28 PM
  #40
Jake1996D1's Avatar
I also want to know which one of these fittings is even remotely close to fitting a d1
male, 1/8"-27 NPT male/female 90° elbow, 1/8"-28 BSPT male x 1/8"-27 NPT female 90° elbow, M8 x 1 male x 1/8"- 27 NPT female straight, M10 x 1 male x 1/8"-27 NPT female straight, M12 x 1.5 male x 1/8"-27 NPT female straight, M14 x 1.5 male x 1/8"-27 NPT female straight, 1/4"-18 NPT male x 1/8"- 27 NPT female, 3/8"-18 NPT male x 1/8"-27 NPT female, 1/8"-27 NPT female x 1/8"-27 NPT female, 1/8"-27 NPT male to male 2" long nipple
