Floor panels / seat mount
Old Jul 14, 2024 | 02:48 PM
Volder's Avatar
Default Floor panels / seat mount
Hello from Denmark
just got my self a 96, 3.9 auto.
I knew that there was rust - just not how much!!
Well, we will just have to sort that out.
I Can find lots and lots of floor panels for the rear cargo area, but none for the front footwell of the the seat base? Will also need the crossmember under the rear seat?
Am I looking all the wrong places?
THANKS!
Søren
Old Jul 15, 2024 | 12:04 AM
JohnZo's Avatar
That's a lot of rust. Maybe try outlets in England. Rimmer Bros or John Craddock, for example. Might have better luck at a scrap yard in a dry climate. Good excuse for a trip to Spain, or Western USA.
Old Jul 15, 2024 | 08:23 AM
WaltNYC's Avatar
Old Jul 16, 2024 | 01:12 AM
Volder's Avatar
Thanks! They do not have the panels either.
I just find it strange with all the repair panels made for LR’s that none is made for the area that are so prone to rust.
must do some fabrication, then
Old Nov 26, 2024 | 09:56 AM
Disco95300tdi's Avatar
Hello,
I have the same problem with rust on drivers side of the car and under the car. Can you please upload some pictures of rapair and by any chance a sketch of rapair metal sheet.
Thank you
greetings from Slovenia
PS: sorry for bad english
Old Nov 26, 2024 | 11:04 AM
whiskeynipple0088's Avatar
if you have rust there, you likely have it at the lower A, B and C pillars and lower sill.
Remove the plastic trim under the doors to inspect.
I read a thread a while back where someone used box steel for the lower sill - it was a little bit bigger but was far cheaper and then they attached sliders to it - worth looking into if it were me.
Plan on removing the front wings (fenders) and cleaning - inspect for dried/cracked seam sealant and re-seam seal at front inner wing to A pillar connection. Also add sealant to the wire grommet that goes thru the A pillar for the door controls - both outside/inside of the outter part of the grommet as well as within the wires that go thru it. (thats what finally stopped the water incursion to the footwells for mine).
Old Nov 27, 2024 | 11:18 AM
disco96sd's Avatar
That's my upholstery pattern ! good luck with repair
nashvegas
Feb 13, 2026 04:15 PM
NoGaBiker
Jul 28, 2024 11:32 PM
paule
Oct 25, 2023 03:59 PM
sarek
Aug 7, 2022 06:36 AM
SadaJones
Jul 3, 2022 09:52 AM
