Front Brakes Lock up
Old Jul 16, 2010 | 03:20 PM
fatlos's Avatar
Default Front Brakes Lock up
ive been having this problem where my front brakes lock up after driving it for it a while... seems to be a issue with heat (i think) beacause if you let the car cool down the brakes release and im able to drive again...ive been trying to figure out what the problem might be and this what i came up with....maybe the pads are sticking and after a while of driving they heat up causing the fluid to expand causing the brakes to lock up... i will check the pads ..btw i do know the master cyclinder was replaced prior to me purchasing the car...and i know there is an adjustment screw on the servo unit...not sure where that screw should be set.... any help would be appreciated
Old Jul 16, 2010 | 05:30 PM
Long Haul's Avatar
I would say you have a bad caliper or brake hose.
Old Jul 16, 2010 | 07:17 PM
Bad calipers.
Old Jul 18, 2010 | 06:09 PM
Danny Lee 97 Disco's Avatar
What are you talking about????
Old Jul 19, 2010 | 02:15 AM
fatlos's Avatar
if you remove the master cylinder (two nuts)...behind that theres a push rod that pushes agaisnt the master cylinder when you apply the brakes...it has a adjustment screw on the tip
Old Jul 19, 2010 | 02:23 AM
fatlos's Avatar
OK seems i got the problem fixed... first thing i did was checked the brake calipers to make sure they were not sticking then i replaced the master cylinder the one it had before looked pretty generic...i guess the guy who replaced it before me chose the cheapest one he could find.... and i bled the system ...no more locking brakes
thegoat1
Feb 25, 2015 03:04 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
chwelch
Apr 15, 2010 08:31 PM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
