Which fuel system?
Old Nov 17, 2012 | 09:10 PM
zer0Point's Avatar
Default Which fuel system?
I have a 1998 Disco LE. Does it use the SFI? Am I reading this manual right?
Old Nov 17, 2012 | 09:50 PM
EFI, each cylinder has its own injector.
Sequential port fuel injection works like a carb, it squirts fuel into the intake and then its sucked into each cylinder as the intake valve opens.
Old Nov 18, 2012 | 12:07 AM
zer0Point's Avatar
Ah! Thanks
Old Nov 18, 2012 | 12:26 AM
zer0Point's Avatar
So... I am sorry for coming off as thick here. I am looking at the D1_Workshop_manual.pdf as downloaded from land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
I am trying to troubleshoot a number of idle/rough-start issues. The reason for the original question is that it has a few sections marked "Fuel System".. The choices being Tdi, MFI, SFI and Mpi. I ruled out Tdi (because obviously I own the petrol version) and the Mpi. The MFI version, when outlining the parts for the fuel system indicated it was distributed ignition and also looked to use a different type of MAF Sensor. This left the section marked "19 - FUEL SYSTEM - SFI" as the only rational choice. I also (upon further reading) says it uses a multiport fuel injection system....
This is terribly convoluted.
Old Nov 18, 2012 | 12:27 AM
zer0Point's Avatar
Wow... I did not expect the forum to auto link that.....
Old Nov 18, 2012 | 01:03 AM
Bkreutz's Avatar
You have SFI, go through the description of parts in the "Fuel system - SFI" section of the rave manual, you will see that all the parts described are on your Rover. The type of fuel injection that squirts fuel into the intake is called TBI (throttle body injection), or CIS(continuous injection system), neither of which were ever used on a LR (or at least the ones I know about which stop at 2004, don't know about the newer ones but I seriously doubt that they do)
Edit, oh, you already figured that out.
Old Nov 18, 2012 | 01:05 AM
zer0Point's Avatar
That's what I thought, bk. I just wanted to hear someone else say it. Thank you!
Old Nov 18, 2012 | 08:40 AM
Thank you for the correction.
Old Nov 18, 2012 | 08:41 AM
There are different engine fuel systems for different parts of the world, the RAVE covers all of them.
HopeItsNotAMoneyPit
Jan 15, 2015 11:28 PM
JumPeR04
Apr 7, 2011 09:52 PM
salve7
Mar 9, 2010 06:06 PM
AK Rover
Mar 20, 2009 09:51 PM
duckprefect
Freelander
Mar 9, 2009 08:27 AM
