Fuel tank question....sorry
Old Aug 3, 2012 | 07:32 AM
  #51
L8brakelou's Avatar
How about you post a link or part number with the cap you think I should buy? I have gotten to caps and both of them did the same thing.
Old Aug 3, 2012 | 12:50 PM
  #52
ihscouts's Avatar
Do you really want to drop the tank? Can't you see what I'm trying to tell you without telling you? Yes, you have the correct cap, now you have two. So what are you going to do with one of them? I see a hole in your future......holy Shiite.
Old Aug 3, 2012 | 12:51 PM
  #53
ihscouts's Avatar
When you get around to dropping the tank and fixing the vent line/purge line then you can use your correct cap and the world will be all wonderful again.
Old Aug 6, 2012 | 10:29 AM
  #54
L8brakelou's Avatar
Ok so the vent line on the truck was fine, but i went ahead and swapped the rubber hose to the filler neck. That was in pretty bad shape. I also put the proper pump housing in the truck as well. It is still building up pressure but it seems to be normal. I haven't really driven the truck enough yet to see if it fixed it. But for now it seems normal. I also changed the fuel filter as well and clean up the fuel strainer filter on the bottom of the pump.
Old Aug 6, 2012 | 06:53 PM
  #55
Danny Lee 97 Disco's Avatar
OK, now go to Harbor Freight and buy a fuel pressure guage to connect to the schrader valve and read the pressure at the fuel rail. S/B 36 psi plus or minus a few.
A good healthy fuel system should build up a noticeable pressure with a healthy hiss when you unscrew the cap.
When you turn the key from off to pos II does the fuel pump come on?
Are there any visible leaks or strong smell of gas?
If not, you should be good to go?
Send donations to dannyleebullseye@hotmail.com via paypal.
aguison
Nov 16, 2012 09:29 AM
1998DiscoverySE
Jul 19, 2012 02:57 PM
G Reeves
Feb 21, 2012 02:39 PM
liner1900
Mar 23, 2009 07:58 PM
