It gets better, The shop couldnt try anything because it could not access OBD 2.
Old Sep 20, 2010 | 02:28 PM
  #41
rhino_e28's Avatar
Originally Posted by okdiscoguy
Autologic should be able to read it. You are not going to get a fix unless someone can scan it. I would highly doubt anyone on here will tell you a fix, and someone needs to be able to go hands on. (with a computer).
If you can not see anything funky with the wiring, you may just have to cough up the $200 and have the shop diagnose it.
What started all of this? Why did you try to read the codes? What was hooked up to it?
I did the head gaskets and pulled the starter to rebuild it.
I called another shop, They said for 90 bucks they will tell me why obd2 inst working.
Old Sep 20, 2010 | 03:00 PM
  #42
rhino_e28's Avatar
No shops in my area have test book. They all have autologic....
Old Sep 20, 2010 | 05:17 PM
  #43
discomedic4's Avatar
Maybe Okdisco or Spike can correct me if I am wrong but I have been told that testbook is the actual name of the dealer software. I don't want to steer you wrong but that is what they call it around here.
Old Sep 21, 2010 | 08:07 AM
  #44
okdiscoguy's Avatar
You are correct. Testbook is dealer proprietary. Autologic, Rovacom, and T4 are all aftermarket versions
To the OP, when you did the head gaskets, if you moved the tps or IACV, it will need to be reset. Something may have been shorted to the ECU, although not common to happen. I would take the other ECU with you and let them take a look. Where are you and what shop are you taking it to? We have 2 great shops I would trust with a diagnosis of this kind, but there are some losers out there.
Old Sep 21, 2010 | 11:37 AM
  #45
rhino_e28's Avatar
I am going to take it to a shop and have them diag the OBD. I feel like if I could get that working I would be in the right direction.
Old Sep 21, 2010 | 11:44 AM
  #46
rhino_e28's Avatar
The RPMs Idle at 1300 then after 10-30 seconds fall to the correct 750. WTF. Its always different.
Old Sep 21, 2010 | 11:59 AM
  #47
rhino_e28's Avatar
Ok, The shop cant take it till tomorrow. SO I am going to give it one last attempt. Any ideas, Please toss any anything you can think of.
Old Sep 21, 2010 | 12:00 PM
  #48
Spencerfitch's Avatar
Haha finally somebody knows what Imgoing through. Though mine seems to be partially related to temperature. Every COLd start I get 2100.. Warm starts 13-1500
Old Sep 21, 2010 | 12:02 PM
  #49
rhino_e28's Avatar
It seems to vary with temp.
Old Sep 21, 2010 | 12:03 PM
  #50
rhino_e28's Avatar
If i just got obd to work....
I would be a lot less lost.
