Grinding and vibration in front end 96 disco 1
Old Jul 29, 2022 | 02:50 PM
bolmach's Avatar
4th Gear
Default Grinding and vibration in front end 96 disco 1
Hello,
I am getting a grinding noise and a slight vibration at the wheels while I am driving my 96 Discovery. I put it in 4WD and still got it. It is there at all speeds. If you place your hand on the differential shifter, you can feel it but not on the transmission shifter. I am new to Land Rovers, and any help would be appreciated.
Thanks,
Phil
Old Jul 29, 2022 | 02:57 PM
JohnZo's Avatar
Have you checked all your fluids? Including both swivel housings, differentials, TC, transmission. When was the last time you lubed the drive shafts?
Old Jul 30, 2022 | 01:13 PM
bolmach's Avatar
4th Gear
Thanks. I will start there.
Old Jul 31, 2022 | 12:31 AM
outono's Avatar
My guess is driveshaft or wheel bearings.
Old Jul 31, 2022 | 11:13 AM
disco96sd's Avatar
check the transfer case fluid level
Old Aug 2, 2022 | 05:57 PM
bolmach's Avatar
4th Gear
I changed the transfer case and front and rear differential fluids and checked the swivels. I still have the same problem.; The vibration only happens when I am accelerating.
Old Aug 2, 2022 | 05:58 PM
bolmach's Avatar
4th Gear
Old Aug 8, 2022 | 12:31 AM
Machinistbutler's Avatar
Any luck finding the problem yet?
cobbcj7
Jun 13, 2013 11:58 AM
javoli001
Oct 22, 2008 06:23 PM
film guy
Dec 20, 2006 11:22 AM
lagebrooks
Jul 20, 2006 11:53 AM
kennims
Jan 22, 2005 08:22 AM
