Heater Help (w/ pic)
Old Oct 14, 2013 | 05:42 PM
BHamms's Avatar
Banned
Default Heater Help (w/ pic)
I need to work on getting my heater blowing hot. Cold weather is near.
The A/C works, and blows pretty damn cold actually. The heater blows, just not hot, or even warm. Looking under the hood, I see one hose and one opening from the firewall, which I get the feeling should hook up somewhere rather than dead ending. I've circled em in the pic. Any suggestions??
1994 Discovery 1
3.9L Automatic
Old Oct 14, 2013 | 06:37 PM
nuclearw's Avatar
On my 97 there is a nipple at the front of the engine on the pass side that hooks up to a set of metal tubes your hose and hose end should be routed through,
i do not see the set in your pic they may have been removed at some point due to leaking. can you get a picture of the front half of your engine on that same side?
Old Oct 14, 2013 | 07:23 PM
TOM R's Avatar
On the 98 d1 there is a hose coming off each heater core nipple, they then hook to metal tubes, one tube bends 90* and hooks to the intake with a Special short 2" long hose with different dia each end.
The other metal tube goes to front of engine bends90* down behind alt and a/c compressor and hooks into lower Rad hose
Iirc the early d1 are run different could be wrong
Old Oct 14, 2013 | 07:25 PM
TOM R's Avatar
The hose in the pic with your hand on it, bet your heater hooks into the 2 pipes it is connecting
Old Oct 15, 2013 | 12:41 PM
WaltNYC's Avatar
General picture of coolant flow..... all this can be found in the workshop manual known as RAVE around here.
Old Oct 15, 2013 | 12:58 PM
BHamms's Avatar
Banned
Thanks. I looked through the manual but I must've overlooked that diagram. Guess I was looking for something more Heater specific.
Here's a pic showing where that hose is connected. Looks like the PO bypassed the heating sytem. Worries me why they would've done that. Leaks maybe?
Old Oct 15, 2013 | 01:15 PM
OverRover's Avatar
"Looks like the PO bypassed the heating sytem. Worries me why they would've done "
Sux but the heater core is leaking.
On a side note.... the center EVAP hose that is on the side of the plenum looks cracked and missing a clamp. This at least will be an easy fix.
Old Oct 15, 2013 | 01:39 PM
WaltNYC's Avatar
Not too many other reasons to bypass the heater core.
Old Oct 15, 2013 | 02:06 PM
BHamms's Avatar
Banned
So I need to replace the heater core and replace the one hose. From what I hear this job is a PIA.
Old Oct 15, 2013 | 02:10 PM
WaltNYC's Avatar
It is not 100% certain the heater core is leaking. Best thing to do is plumb the hoses correctly and find out. If the heater core leaks you'll know in short order. At that point you can always pull the hoses and revert to your current state of affairs.
Yes, the heater core is DEEP in the dash and a PITA to replace.
ls1morethanyou
Jan 12, 2017 10:21 AM
oysterhead
May 16, 2011 10:42 AM
Disco2Fever
May 19, 2010 12:46 AM
alanroberts50
Nov 11, 2009 03:40 PM
aircraftguy
Nov 15, 2008 08:37 PM
