Hello from russia, i have a qwestion!
Old 04-15-2012, 01:41 PM
ihscouts's Avatar
SWITCH-VOLT SENSITIVE, 45 AMP, SWITCH VOLT SENSITIVE
Part number: PRC4427
USED 1,089.00 (Roubles) 1 5 PRC4427 1 Реле перезарядки X
Under dash or under steering column cover.
  #22
Old 04-16-2012, 11:20 AM
lostin's Avatar
I repair starter, now rotating good
I check fuel pump - its good
And when i check voltage on pump connector withowt pump - it 12 volts, if with pump - 0.3 volts
on fuse - 12v
on relay -12v
on pump - 0.3v?
WHY?
  #23
Old 04-16-2012, 06:49 PM
Is it always at .3v? Or does it drop after a few seconds?
  #24
Old 04-16-2012, 10:12 PM
lostin's Avatar
drop after ~10 sec.
  #25
Old 04-17-2012, 09:34 PM
That is perfectly 100% normal, the fuel pump shuts off after 5-10 seconds if the engine is not running, again, that is normal.
  #26
Old 04-19-2012, 08:32 AM
lostin's Avatar
Make wire from relay to pump - engine started.
Gleb 501Russia
04-02-2014 08:35 AM
Grimm
03-25-2010 06:17 AM
Quick Reply: Hello from russia, i have a qwestion!
