Hello from russia, i have a qwestion!
Old Apr 15, 2012 | 01:41 PM
  #21
ihscouts's Avatar
SWITCH-VOLT SENSITIVE, 45 AMP, SWITCH VOLT SENSITIVE
Part number: PRC4427
USED 1,089.00 (Roubles) 1 5 PRC4427 1 Реле перезарядки X
Under dash or under steering column cover.
Old Apr 16, 2012 | 11:20 AM
  #22
lostin's Avatar
I repair starter, now rotating good
I check fuel pump - its good
And when i check voltage on pump connector withowt pump - it 12 volts, if with pump - 0.3 volts
on fuse - 12v
on relay -12v
on pump - 0.3v?
WHY?
Old Apr 16, 2012 | 06:49 PM
  #23
Is it always at .3v? Or does it drop after a few seconds?
Old Apr 16, 2012 | 10:12 PM
  #24
lostin's Avatar
drop after ~10 sec.
Old Apr 17, 2012 | 09:34 PM
  #25
That is perfectly 100% normal, the fuel pump shuts off after 5-10 seconds if the engine is not running, again, that is normal.
Old Apr 19, 2012 | 08:32 AM
  #26
lostin's Avatar
Make wire from relay to pump - engine started.
Gleb 501Russia
Apr 2, 2014 08:35 AM
nelsontod
May 18, 2012 12:20 PM
Grimm
Mar 25, 2010 06:17 AM
USMC_Denver
Apr 21, 2009 05:58 PM
