Help. Disco running rough and rich
Old May 16, 2012 | 06:11 PM
Originally Posted by fishEH
How does one go about checking an O2 sensor to verify it is working properly?
With a live data OBDII scanner.
Old May 17, 2012 | 04:58 PM
ADDAM's Avatar
8th Gear
Ok I got it fixed, all it was is a dirty throttle body. Now it has a high idle though?? 1700rpm idle
Old May 17, 2012 | 05:37 PM
fishEH's Avatar
That doesn't sound fixed. Sounds like mine is acting right now. Hi/Lo idle, hesitate's at a stop when gas is applied, and gutless/missing between 1500-2000rpm. Ugh.
Old May 17, 2012 | 06:50 PM
ADDAM's Avatar
8th Gear
The only thing wrong now is the high idle. The stalling is fixed
Old May 17, 2012 | 07:24 PM
A failed TPS can allow engine to only go to about 1700 rpm. An IACV or vac leak problem (un-metered air after the MAF) ?
Old May 17, 2012 | 09:29 PM
Jake1996D1's Avatar
Also check to make sure the throttle plate is fully closed - and that one of the wires isnt holding it from closing completely. Spray some silicone based lube on them.
Drive it for a couple days and report back.
Old May 17, 2012 | 11:21 PM
ColoDisco's Avatar
I am currently fighting a code 48 with these exact same symptoms. Already cleaned my IACV. I do still need to set my base idle since replacing my cam and lifters. I found that if I clear the faults it runs fine for about a day then idle stumbles and CEL comes back on.
dillhole
Feb 20, 2020 02:30 PM
rick williams
Nov 29, 2013 08:10 PM
pvflyer
Mar 26, 2013 08:45 PM
vpadferg
Jan 19, 2013 09:41 PM
jake0258
Jan 15, 2012 11:57 PM
