Help. Disco running rough and rich
That doesn't sound fixed. Sounds like mine is acting right now. Hi/Lo idle, hesitate's at a stop when gas is applied, and gutless/missing between 1500-2000rpm. Ugh.
Also check to make sure the throttle plate is fully closed - and that one of the wires isnt holding it from closing completely. Spray some silicone based lube on them.
Drive it for a couple days and report back.
I am currently fighting a code 48 with these exact same symptoms. Already cleaned my IACV. I do still need to set my base idle since replacing my cam and lifters. I found that if I clear the faults it runs fine for about a day then idle stumbles and CEL comes back on.
dillhole
Feb 20, 2020 02:30 PM
