Help! Stripped nuts and bolts removal...
Old Feb 13, 2017 | 11:56 AM
FLA Rover's Avatar
Default Help! Stripped nuts and bolts removal...
Any one have a trick to remove stripped nuts and bolts from TC side of front Axel? Cutting wheel and grinder I have is too big to get at them...
TC side of front shaft...
Old Feb 13, 2017 | 02:19 PM
fishEH's Avatar
Cut the bolt head side. Rotate the shaft for access. Should be plenty of room for a sawzall or dremel wheel.
Old Feb 14, 2017 | 08:26 AM
Paul Grant's Avatar
If it's too tight for a sawzall or dremel, use a chisel and hammer. Once you get the nut turning it will back out pretty easy.
Old Feb 15, 2017 | 01:13 PM
hrhoward's Avatar
A shaped explosive charge. Make sure you only use a wee bit.
Old Feb 15, 2017 | 01:38 PM
fishEH's Avatar
Plasma torch!!!!
Old Feb 15, 2017 | 02:54 PM
ihscouts's Avatar
Ferengi energy whip!
Old Feb 15, 2017 | 06:25 PM
Detoured Discovey's Avatar
Fuel leak, bad starter connection, and a paid to date good homeowners policy or auto policy if you chose not to park next to dwelling.....
Savannah Buzz
Jul 6, 2013 05:22 PM
dcarr1971
Feb 8, 2013 08:16 AM
ralford
Oct 17, 2012 08:41 AM
jordamf
Sep 6, 2011 08:18 AM
97DISCOIDAHO
Aug 30, 2006 02:57 AM
