Help - Valley Pan Gasket Does Not Line Up
Old Jul 26, 2013 | 01:39 PM
  #31
More pix
Took out gasket and front end seal, intake went into position with front two 7/16 bolts
Installed inserts in 11 of 12 holes. Having touble getting insert to go into hole with real helicoil, even though bolt of same thread goes in like butter. Spent time buying screwdriver, won't fit inserts, filing it down, cracking the high crabon inserts, going to buy more ez outs because I can't find mine, etc.
Here is new gasket on smaller holes (5/16 vs 3/8 oem). Not looking good. Also note where I cleaned off grease, head does not appear to be perfectly square on block (it is on the index pins). Will try sitting intake on there, pushing down on gasket not going very far.
Attached Thumbnails Help - Valley Pan Gasket Does Not Line Up-p1130472.jpg   Help - Valley Pan Gasket Does Not Line Up-p1130469.jpg   Help - Valley Pan Gasket Does Not Line Up-p1130470.jpg   Help - Valley Pan Gasket Does Not Line Up-p1130466.jpg   Help - Valley Pan Gasket Does Not Line Up-p1130471.jpg
Old Jul 26, 2013 | 02:31 PM
  #32
fishEH's Avatar
It looks to fit "ok" and could maybe be made to work. Why would you replace a jacked up VR gasket with another potentially jacked up VR gasket????
Old Jul 26, 2013 | 06:00 PM
  #33
All I could get quickly, and that had to come from Augusta overnight (Advance, $43).
So new gasket won't line up with 5/16ths bolts. Took it out, put one I was having problems with back in, the holes already drilled out on it. All bolts in, torqued to 30 nm, which is as far as I dare with 5/16. RTV'd around 4 water ports lightly. My one 7/16 helicoil bolt lined up and stayed that size.
Hoping to get back together and running tomorrow.
Attached Thumbnails Help - Valley Pan Gasket Does Not Line Up-p1130473.jpg   Help - Valley Pan Gasket Does Not Line Up-p1130475.jpg   Help - Valley Pan Gasket Does Not Line Up-p1130478.jpg
Savannah Buzz
Jun 23, 2013 03:46 PM
jpmiller
Sep 26, 2012 06:32 AM
JHDisco2
Dec 15, 2009 10:58 AM
chad420
Oct 24, 2009 02:51 PM
JimScream
Jan 6, 2009 02:01 PM
