how to check my timing???
Old Mar 29, 2012 | 11:36 PM
collin Barrows's Avatar
Default how to check my timing???
Hello all, I noticed that my Disco's timing is off. I have a timing light and the rave manual, the only problem is that my rave manual is missing this part. If anyone could help I would be very thankful.
Old Mar 30, 2012 | 04:12 AM
Do you have a distributor? If "NO", each cylinder timing is controlled seperately by the ECU and the knock sensors. If "YES", it is in section 5 of the workshop manual, starts on about page 44, "Engine Tuning Data", tells timing mark locations, various degrees of advance at rpms, etc.
Old Mar 30, 2012 | 12:36 PM
ValveCoverGasket's Avatar
how did you check?
Old Mar 30, 2012 | 11:34 PM
Banzai Jimmy's Avatar
My guess is he checked the timing with the timing light. What he needs to know is how to loosen the distributer clamp, rotate the dizzy to get the base setting he wants and tighten the clamp back up. Of course one should then ensure that the timing didn't change during the clamp tightening.
Old Mar 30, 2012 | 11:53 PM
I ask because some of these trucks don't have distributors, and there's little one can do to adjust in that case
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
tads
Aug 2, 2007 12:09 PM
VB_Rover
Jun 8, 2005 11:51 PM
