I love compressed can air
Old 05-27-2011 | 02:34 PM
kamileon's Avatar
Default I love compressed can air
So I had my no start issue come back a couple of days ago, hot out side with cold engine and no start. So pissed off, I walked back to my work desk and right in front of me was my can of air. The thought popped into my head that maybe the fuel temp sensor is giving a hotter reading than normal causing the no start issue. So I took my canned air and turned it upside down and sprayed the liquid inside on the fuel temp sensor to give it a bit of a freeze. Immediately jumped into the disco and it fired right up. Thinking this was just a fluke or something, I took the canned air with me when I left work last night, and lucky me (or unlucky depends on how you see it) it wouldnt start. Sprayed the sensor with the canned air again and it fired right up. So at least I narrowed down my problem, I think. Gonna order a new sensor and see if that resolves my problem, or just carry a can of air in the vehicle, it is cheaper.
Old 05-27-2011 | 08:26 PM
You have re-discovered the old radio and TV repair trick - spray each suspected component with carbon tetrachloride (or brake cleaner or circuit cleaner); which cools off the item. Then as it warms up, if the system changes you have found the part to swap. Of course, nobody does that anymore, they just swap modules (kind of like the younger techs at the stealership)
Old 05-30-2011 | 01:18 AM
honda50r's Avatar
the stealership)
I love this term, patent that.
Old 05-30-2011 | 09:07 AM
Those who emptied wallets before becoming greased fingered wrench benders before me came up with it.
Alex_M
03-09-2015 05:56 PM
