If I use my factory tow ring as a recovery point...
Old Jun 30, 2010 | 04:59 AM
jeffrudy's Avatar
whats an owners manual ?
Old Jun 30, 2010 | 06:44 PM
Danny Lee 97 Disco's Avatar
After reading the statement that the owner's manual syas there is a front hook as well as the two tie-down points, I had to go out to the driveway and take a good look at the Discovery.
I had removed my factory brush bar long ago due to corrosion. I also removed the facory air dam, plastic end caps, fog lamps, all the way down to the bare-*** bumper.
All I see is the two lashing points. No factory tow hook of any sort. The rear also has two different shaped lashing points and the factory recptacle on the rear bumper for a tow/trailer hitch or recovery hook.
As far as hooking up to the front you could either try to slip something over the frame crossmember but there's not much clearance, or push back the white plastic trim over the bumper and wrap it around the two frame mounts and the bumper.
You should go ahead and install a good tow point if you think you may need to ****** it out. You don't want to be stuck and have the bumper ripped off as well.........................
Old Jun 30, 2010 | 07:31 PM
AK Rover's Avatar
If your Disco has the factory brush bar the tow loops are at the bottom of the brush bar and the one from the frame is removed. That's how my 97 Disco was. In the rear the tow loops are also the tie down points. I haven't figured out why they didn't do that on the front as well.
Old Jun 30, 2010 | 07:48 PM
The brush bar mounts to the front bumper which has four bolts attaching it to the frame. Now that you mention it, I do remember one on the brush bar.
I had a friend who mounted a large capstand from a ship on the front of his, then he just looped a strap over the capstand.
Old Jun 30, 2010 | 09:23 PM
I would not trust the recovery point on my brush bar to save AK's life.
Well, ok, maybe his, but not mine, no way in hell.
Old Jul 1, 2010 | 03:02 PM
Pwn777's Avatar
My back ones are all rusted over, they hadnt been used at all before when i got the rover, ive used them many times in high stress situations, they handled like champs.
Old Jul 1, 2010 | 06:27 PM
Spencerfitch's Avatar
hell whats the worse that could happen? they break off?
Make sure nobody is in the line of fire and use a jacket or blanket as a suppressor incase it breaks free.
Old Jul 2, 2010 | 10:43 AM
AK Rover's Avatar
I actually used the tow points on the bottom of my brush bar a number of times without problem. Not something I would want to do all the time but it works well enough for the occasional recovery. I even got pulled out of a snow bank by the tie-down loop once. Bent the crap out of the loop but I came out of the snow bank.
I'm a firm believer in throwing a jacket or something over a tow strap or winch cable any time I do a recovery. I've been fortunate and the only damage I've seen caused by flying straps or chains that broke has been to vehicles and not people but I still don't like to risk it. It's too easy to throw something over the strap or cable to weigh it down in the event of it snapping to risk someone's life.
TopGunRover
May 21, 2015 06:40 AM
expedio2005
Apr 7, 2014 08:34 AM
MrHSE7
Feb 11, 2014 12:39 PM
olywa
Jan 28, 2012 10:23 PM
S4poor
Feb 10, 2008 10:15 AM
