IM BACK!!!! This time with over heating issues.
It shouldnt free spin, im not however good at diagnosing fan clutch problems.
Does it happen when sitting in traffic only? this is a dead giveaway
I bet it is a clogged radiator.....
Ask if someone near you has a infrared termometer or buy a cheap one and measure the temp in all the radiator. Actually, if you turn on the AC, the fans would help to push air in the radiator and will also help to cool it down.
another trick you can use to reduce the overheating at list for a few additional minutes while you are driving is to turn on the heat in your car. The heater uses the heat of the engine, and helps to keep it cool.
SolbergFanBoi
Mar 5, 2012 07:05 PM
