IM BACK!!!! This time with over heating issues.
Old Sep 29, 2010 | 09:02 PM
Spencerfitch's Avatar
Originally Posted by rhino_e28
I can turn the fan manual right after shutting off the motor. Bad fan clutch?
It should have resistance when hot or super cold [hasnt been spinning]
It shouldnt free spin, im not however good at diagnosing fan clutch problems.
Does it happen when sitting in traffic only? this is a dead giveaway
Old Sep 29, 2010 | 09:12 PM
Danny Lee 97 Disco's Avatar
Don't keep overheating it or you will kill that aluminum motor.
Old Sep 30, 2010 | 04:01 PM
johnkbl's Avatar
I bet it is a clogged radiator.....
Ask if someone near you has a infrared termometer or buy a cheap one and measure the temp in all the radiator. Actually, if you turn on the AC, the fans would help to push air in the radiator and will also help to cool it down.
another trick you can use to reduce the overheating at list for a few additional minutes while you are driving is to turn on the heat in your car. The heater uses the heat of the engine, and helps to keep it cool.
Old Sep 30, 2010 | 06:35 PM
Let me ask a basic question: If you took the hoses loose, could you do a basic flush with a garden hose? Would that tell you anything?
Old Oct 1, 2010 | 12:05 AM
bantham1's Avatar
Check your radiator. You can have it rodded out for about 75 dollars. Well worth it. Old radiators in these vehicles clog easily. If it is clogged flushing with a hose will do little. You need to have it rodded.
Flyin2jz
Dec 16, 2012 12:02 AM
vALEXv
May 27, 2012 12:11 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
RRDude
Feb 2, 2011 04:58 PM
budley62
Jan 3, 2006 05:36 AM
