I'm slightly enjoying documenting my problems on here. Power steering MASSIVE leak!
Old Aug 17, 2013 | 05:14 PM
formel3's Avatar
Default I'm slightly enjoying documenting my problems on here. Power steering MASSIVE leak!
Hey everyone-today I have developed a somewhat MASSIVE power steering leak. Seems to be coming from the black master cylinder like thing. It's coming from around one of the holes that the line goes into-It leaks enough that its getting all over the driver's side front brakes. Wondering if that has anything to do with my recently developed ABS issue. Wondering if that part is a typical place for it to fail, or could it be as simple as the line is loose? Engine is just too hot right now to mess with it. Let me know what you think.
Old Aug 17, 2013 | 08:29 PM
Certainly should not be leaking or spraying that red ATF fluid. Can try snugging up the fitting. Can also try Lucas ATF fix (it is ATF fluid after all). That's right, D1 uses ATF red fluid in the power steering.
bosshogt
Dec 23, 2011 10:24 AM
adamlanders
Nov 3, 2011 09:59 PM
momentum59
Aug 11, 2010 06:36 PM
mcrw
Jan 17, 2009 01:15 PM
disco1guy
Jan 27, 2008 08:26 AM
