Labour Estimate
Old Sep 3, 2011 | 06:47 PM
antichrist's Avatar
Land Rover Book time in hours:
  • Install new front TC output flange (for DII shaft) with OEM seal. Flange/Seal brand new from GBR. - 1.5
  • Re-seal TC cover (since it was being drained for the new flange) - .45
  • Install new GBR DII front shaft. - .55 ( about 1/2 of that would be covered changing the output flange)
  • Build brackets to lower sway bar as it was hitting the new shaft. - actual time, so that would be easy to pad
  • Transmission drain & filter - 2.05
  • Replace Fuel Filter - .60
I've found alldata to be way off base on many things.
If he charges actual time, then it could be higher depending on how rusted things are.
pilsner
Jun 21, 2009 03:18 PM
D2
Nov 14, 2008 01:43 PM
BainbridgeRover
Dec 13, 2007 01:51 PM
rovernbama
Apr 28, 2006 01:33 PM
05LandRover
ROAMING WITH FRIENDS
May 24, 2005 01:48 AM
