repair estimate?
Old Jun 20, 2009 | 01:42 PM
pilsner's Avatar
Default repair estimate?
ok, first off - an apology. i just KNOW that there is at least one thread about this but i got outsmarted by the new search function. so im gonna ask again.
2000 disco II w/140k miles
needs new head gasket. i know the parts are around $200 (including new head bolts.)
what i need to know is what is a reasonable shop rate for this - non dealership - as in $/hr
and how many hours for R/R is reasonable.
assuming of course that nothing else is wrong once we open it up.
thanks -
brian.
btw - wouold i be better off just having the whole damn thing rebuild or just the head gaskets?
Old Jun 20, 2009 | 02:22 PM
The labor fora 2000 without SAI is 10 to 11 hours at what ever the shop charges which could range from $1000 to $1200 in labors plus any additional sublet for heads.
Old Jun 20, 2009 | 05:05 PM
pilsner's Avatar
ok, so 10 - 12 hours. got it
is this the right part?
http://www.roverparts.com/Nxt/search...very+Series+II
anything else i should know before i start this process?
MIKE: as always i appreciate all of your time and answers! thank you
Old Jun 20, 2009 | 08:59 PM
Yes, along with a new t/stat and upper hose assembly if you haven't already up-grade to the new system with the relocated bleeder screw.
Old Jun 21, 2009 | 12:59 PM
pilsner's Avatar
i put in a new t/stat last winter - is it still good or do i need to replace it?
Old Jun 21, 2009 | 03:18 PM
T-stats are good until they go bad, since you just replaced yours last year I would not worry about it.
03blues
Feb 18, 2010 05:54 AM
D2
Nov 14, 2008 01:43 PM
BainbridgeRover
Dec 13, 2007 01:51 PM
rovernbama
Apr 28, 2006 01:33 PM
05LandRover
ROAMING WITH FRIENDS
May 24, 2005 01:48 AM
