LED brake lamp w/ built in load resistor part #
Old Sep 30, 2022 | 01:53 PM
dcphotos's Avatar
Default LED brake lamp w/ built in load resistor part #
I installed LED brake lamps and now my cruise control no longer works. Does anyone know of an LED bulb that has a built in load resistor I can just plug in.
(I promise I've searched)
I really don't want to wire-in a resistor if I can help it.
TIA,
Don
Old Sep 30, 2022 | 04:33 PM
JohnZo's Avatar
I suspect something else happened coincidentally, because the LED load resistor is only so the turn signal flasher works right (neither of my Discos needed a resistor, by the way). Did you check the vacuum valve device on the brake pedal (mine broke recently, one of the hooks snapped off)?
CC has a lot of things that can go wrong (Module board soldering faults are very common, steering wheel buttons, RR wheel sensor, vacuum system components, and brake switch). My Set/Accel button recently stopped working in the middle of a drive. I need to get in there with a multimeter at the module. I have the CC wiring diagram in my notebook (somewhere).
Old Oct 3, 2022 | 01:08 PM
dcphotos's Avatar
JohnZo,
Thanks for replying. I did check all the vacuum hoses, etc. No Joy. I have read on this forum and others that the LED's have a lower resistance and it throws the CC module off as it is looking for a certain resistance and when it doesn't see it, it assumes you have your foot on the brake, thus kicking it out or not allowing CC.
Thanks,
Don
Old Oct 3, 2022 | 08:33 PM
JohnZo's Avatar
Just to a look at the 96 wiring diagram. All the logic is 12 V or ground, with no interface with the actual brake light bulbs. There are three input signals related to the brake pedal, and the switches can be mis-adjusted. Do you have access to the ETM and wiring diagrams?
If it was attached to the bulbs, wouldn't it fail if a bulb burned out? By the way, LEDs present a higher equivalent resistance, not lower. They draw lower amps. That is why they burn less wattage. Wiring in a resistor (in parallel) is to pull more amps so the flasher burnout detection gets tricked. I'll take a look at the 97 diagram and let you know if it's different than the 96.
SWM
Jan 15, 2022 08:50 PM
scader
Jul 22, 2019 11:23 AM
TRIARII
Dec 9, 2013 06:24 PM
keithlarue
Dec 5, 2013 06:43 AM
kpl1228
Feb 19, 2012 07:33 AM
