Likely spot for leak
Old Jun 5, 2019 | 06:25 AM
hrhoward's Avatar
Default Likely spot for leak
Had to wiggle some wires on my fuel pump and found rust. Where are the typical spots to check for a leak? Rest of the cargo area is fine.
Old Jun 5, 2019 | 10:59 AM
WaltNYC's Avatar
My first guess would be the Alpine window.
Another thought is that the weather stripping which seals the rear cargo door is old/worn out/ not seated properly.
One more would be the tail lights/indicators/reverse lights.
Old Jun 5, 2019 | 01:06 PM
hrhoward's Avatar
Thanks Walt.
Weatherstripping is good. I checked it with a dollar bill. Closed the door on a dollar bill and had resistance pulling along the sides and top of door.
I'll check the tail-light but not keen on messing with the alpine until I do the headliner.
Going to brush it off and baste it with some SEM Rust-Shield.
Old Jun 5, 2019 | 06:02 PM
aemnky606's Avatar
Check the seals around your glass. Mine had a crack in the top corners that let water in.
Old Jun 9, 2019 | 10:05 AM
hrhoward's Avatar
Walt, aemnky606,
Ended up being a missing plug from top center of rear wheel well.
Old Jun 9, 2019 | 10:11 AM
aemnky606's Avatar
Well that was an easy fix. Wish mine had been that easy.
archaeology_student
Aug 7, 2013 03:23 PM
aarongregor
Mar 24, 2013 10:09 AM
bcolins
Nov 1, 2012 08:29 PM
kevlor80
Apr 13, 2012 10:17 AM
cjaclwill
Dec 5, 2011 04:41 PM
