Which line vents the gas tank when adding Gasoline
Old Jan 21, 2017 | 01:12 PM
mr4x4's Avatar
Heres how i fixed my 99 when the gas pump kept shutting off while trying to fill it up.
Step 1 open hood lol
Step 2 disconnect plastic hoses that connect to the evap canister
Step 3 With gas cap off use compressed air to blow into the line that goes to the gas tank from the evap canister.
Step 4 with both lines disconnected from evap canister blow compressed air into one port of the evap canister and allow it to travel out the other port.
This should clear any debris out of the evap system if that's your issue. Idea cam from this video.
https://www.youtube.com/watch?v=B7EcWwlhzBM
Old Jan 21, 2017 | 01:14 PM
mr4x4's Avatar
https://youtu.be/B7EcWwlhzBM
Old Jan 24, 2017 | 04:20 PM
reboot's Avatar
Actually I saw that before I asked in here, but had my doubts. Anyway, I took my Shopvac which also is a blower and used it to suck and blow into any and all places I could as well as the charcoal canister. I went and fueled the Disco the next day, ready for this, not one cut off. Ok, so we'll see from here and I'll post the next fueling.
Old Jan 24, 2017 | 05:53 PM
mr4x4's Avatar
yep I did the same and it doesn't shut off for me. Glad you got it going
Old Feb 11, 2017 | 04:40 PM
reboot's Avatar
I guess the trickle valve is the next step. Went to fill (had a little less than half a tank) and it started cutting off the pump again.
Old Feb 12, 2017 | 03:41 PM
reboot's Avatar
this is interesting, I'm going to try it:
There's a Part 2 also.
Old Apr 26, 2017 | 04:18 PM
reboot's Avatar
well, I gutted my trickle valve about 3 weeks ago and have not had a problem filing the tank. I can hold the gas nozzle wide open, not even a burp.
n1keaddict
Mar 5, 2022 08:50 PM
Eak69
Apr 4, 2010 11:52 AM
leadfoot
May 7, 2009 09:39 AM
carlitonsky
Jan 29, 2009 09:53 PM
briancbev
Apr 11, 2008 09:24 PM
