Making sense of it all
Old Aug 25, 2013 | 09:59 AM
FLA Rover's Avatar
Default Making sense of it all
Ok I know I have a 4.0L in my 98. Decal on back shows V8i, I do know the V8i has aluminum heads and block. My fuel system is an SFI. I guess my question is what is the difference between the 3.9 and the 4.0L? And I've already heard .1L. Is it just a model year switch? I guess what's confusing me is when I look at RAVE it shows the V8i as a 3.9L.
Old Aug 25, 2013 | 10:08 AM
market hype. They are both 3950 cc, bore and stroke the same. Pages from spec area of RAVE shop manual attached. I guess the older 3.9i had distributor, vs the GEMS coil pack in the rear set up. The 3.9 is rated for slightly less power output. So maybe a difference in cam duration. Valve lift is the same.
File Type: pdf
Old Aug 25, 2013 | 11:19 AM
jafir's Avatar
Cross bolted mains on the 4.0 too. Bigger main journals also.
GLOCK3462
Dec 21, 2012 08:01 PM
Bduncan26
Feb 19, 2012 07:59 PM
DiscoBenjamin
Jun 9, 2011 11:07 AM
lipadj46
Mar 25, 2009 11:53 AM
ek5usmc
Sep 20, 2008 06:21 PM
