mesh grill write-up
Old Jun 28, 2014 | 05:58 PM
  #141
HammerFit's Avatar
Originally Posted by TOM R
i did mine, the aluminum mesh I used was from home depot and the same brand as in the thread, think I used hot glue it worked well till we cut the grill for the winch need to re glue mine
Tom did you use the 6" gutter guard at home depot?
Old Jun 28, 2014 | 07:34 PM
  #142
TOM R's Avatar
I can measure in the morning, I know is it was the same as page 1, and I did not trim it it is just the right size
Old Jun 30, 2014 | 06:17 PM
  #143
HammerFit's Avatar
Yup the gutter guard does fit in there without any trimming at all. That's pretty strange.
Glad I'm doing this, taking out all the turn signals and headlights has shed some light on why everything doesnt line up just right. Now being the **** idiot I am I will get everything sorted out before putting back in. Got it blue tapped and just going to use the angle grinder. Screw the corners, not enough difference to go to that much trouble. Gonna leave it raw, I like the contrast against the black. Pics tomorrow.
Old Jun 30, 2014 | 09:49 PM
  #144
TOM R's Avatar
I found those vibrating cutting tools work perfect cutting plastic with good control
Old Jul 1, 2014 | 08:35 AM
  #145
HammerFit's Avatar
I used a jig saw and it came out good and was easy to do corners w jig. I'm not to sure the liquid nails is going to hold on it's own. I've got concrete blocks sitting on it letting it cure.
Old Jul 1, 2014 | 01:15 PM
  #146
TOM R's Avatar
Yeah lmk how that turns out, I need to reglue mine, finding a good adhesive for the application seems difficult
Old Jul 1, 2014 | 03:44 PM
  #147
HammerFit's Avatar
Liquid nails failed I just applied an entire canister of gorilla glue 2 part epoxy Ive got blocks and clamps holding it down, supposed to setup in 30 mins Probally gonna glue the blocks and clamps down too!
I think you need something thicker so that it fills the voids
I will say the liquid nails worked wonders on one of my headlights. 2 of the sockets were broken that that the ball studs fight into. Put a dab of the nails on them and whala no more loose headlight!
Old Jul 1, 2014 | 04:44 PM
  #148
TOM R's Avatar
I had also used a 2 part epoxy it has held but a bitch to use to liquid, need a gel or paste type that works on plastic
Old Jul 1, 2014 | 07:27 PM
  #149
HammerFit's Avatar
Ok, stick a fork in this project. I must say I really like it. Very clean lines. I also paint all the trim with flat black trim paint. I didn't have the LR sticker on for the pic but it's on now curing until morning.
The trick to this at least for me was to curl the bottom of the material under a bit to conform to the shape of the plastic at the bottom.
A jig saw made short order of cutting it out. As others have stated, cutting is easy, gluing metal to plastic, different story.
Old Jul 5, 2014 | 01:39 PM
  #150
TOM R's Avatar
Glue mine back on with locktite epoxy plastic bonder it is like a paste in a double syringe to mix sold at Lowes will see how it holds
