mesh grill write-up
Old Jul 5, 2014 | 02:29 PM
  #151
HammerFit's Avatar
Mine fell off the next day after using Gorilla 2 part epoxy. I read the label AFTER it fell off and I guess I didn't read the part about 24 hr cure time. It was setup and holding when I put in on. Going to try Jen Weld 2 part epoxy now. I think I will review the directions first this time.
Old Jul 5, 2014 | 03:34 PM
  #152
TOM R's Avatar
Mine is still fine today, been driving around, I have used this same stuff on star wars armour and such with good results so hope it lasts
Old Jul 14, 2014 | 03:15 PM
  #153
HammerFit's Avatar
Unbelievable! The damn thing fell off again! Well I bet it doesn't come off now. Can you see the SS bolts w nylon lock nuts?
Old Jul 14, 2014 | 10:13 PM
  #154
TOM R's Avatar
Mine still holding after went n.j. to va. and back
Old Jan 6, 2015 | 07:53 PM
  #155
socal1200r's Avatar
Default Grill removal
I picked up a spare front grill from the local salvage yard, cut out the middle section, and found some clover-leaf aluminum mesh (think of a pet guard for a screen door) to cover the middle. I attached the mesh with small bolts and fender washers (2 on each side, 3 along the top and bottom), then painted the whole thing with bedliner coating.
My question is, what is the preferred way to remove the stock grill and install the new one without damaging anything? The reason I ask is, when I removed the one from the salvage yard, I removed the three bolts up top, and was surprised that it was still "stuck". It looked like the center grill slid over the ends of the corner pieces. It looked like the side pieces have to be removed as well, which requires removing the turn signal housings.
Am I missing something, or should I remove the side pieces and turn signal housings to swap the center grill?
Old Jan 6, 2015 | 08:17 PM
  #156
TOM R's Avatar
Yup pull the side pieces, remove screws on top, pull up
Old Jan 7, 2015 | 09:37 AM
  #157
fishEH's Avatar
The turn signals are removed by releasing a single spring.
Old Aug 24, 2015 | 09:08 AM
  #158
redrover99's Avatar
Old thread but figured I would throw in my homemade version of the saudi grill.
Contrary to what others said, I believe the saudi grill does help cooling by allowing more air flow, my temp has dropped from 206F to around 188F after the grill( and removing lights, ect. from ARB)
Old Aug 31, 2015 | 09:58 AM
  #159
vegas99d1's Avatar
Default Here's the part number for the mesh from Lowes
Shop InvisaFlow Galvanized Steel Gutter Guard at Lowes.com
Item #: 502138 | Model #: 6360
4.5 / 5
29 reviews | Write a review
$2.98
Series Name N/A
Gutter Style K style
Requires Sealant No
Width (Inches) 6.13
Length (Inches) 36
Package Quantity 1
Manufacturer Color/Finish Black
Warranty 10-year limited
Color/Finish Family Black
Material Galvanized steel
Type Gutter guard
Old Sep 1, 2015 | 10:07 PM
  #160
tweakrover's Avatar
I'm truly amazed that this thread is still going, but it inspied me, I need to carry on the Saudi grill tradition with my new rover.
Bring the Saudi grill to the p38, what you think?
