My 1997 Discovery 1 V8i 3.9L has intermittent starting problem
Old Sep 12, 2021 | 10:51 AM
  #31
JohnZo's Avatar
Hi Sam, I was wondering how you are doing. An easy check for the battery terminals is to turn on your headlights (engine off) and measure voltage directly on the lead battery terminals, then measure on the clamps or wires leading away from the battery. If the voltages are equal, the connections are good. If the voltage on the clamps is lower, then the connections need polishing. The higher amps of the starter motor will make the voltage drop even lower, and that could be effecting the ignition. Good idea to get a new battery. We probably should have started there. Check the simple things first.
vashonrovermechanic
Sep 21, 2011 02:50 PM
reno-lr
Nov 18, 2009 08:12 PM
mrsbntn
Nov 19, 2008 06:55 PM
petrosnikol
Nov 3, 2008 04:46 PM
dinava
Sep 15, 2008 10:19 AM
