NEED HELP 1. Tape stuck on eject 2. Misfire Cylinder 5/6
Old Aug 21, 2023 | 02:19 PM
heyhannah's Avatar
4th Gear
Default NEED HELP 1. Tape stuck on eject 2. Misfire Cylinder 5/6
2004 Land Rover Disco
First off took off battery plugs to reset system, ever since tape is stuck on eject mode, and the tape wont come out. Any advice please share.
Next, the Engine Light came on. Checked codes, ran Cylinder 5/6 misfire. Car sounds rough, a slight shake to the car, rumble noise. Heard might be spark plugs.
third time the engine light has come on in the past 2-3 months.
Anything helps. Much thanks
Hannah
Old Aug 22, 2023 | 10:17 AM
WaltNYC's Avatar
1. You have posted in the Discovery 1 section (1993-1999)
2. spark plug and/or spark plug wire could be a simple fix.
3. Do you have a code reader? If not, get one like this... https://landroverforums.com/forum/di...02/#post581013
4. Manuals (aka: RAVE) can be found in the link in my signature. Help yourself.
carmonalandrover
Mar 11, 2021 08:22 PM
mdwman
Aug 2, 2014 05:24 PM
apcollin
Oct 19, 2009 03:47 PM
casanova00
Jul 28, 2008 10:57 PM
louianquin
Freelander
Jun 9, 2008 03:18 AM
