Need help to determine engine year
Old Feb 15, 2013 | 12:52 PM
NabisOne's Avatar
Default Need help to determine engine year
When I bought my Disco the guy told me the previous owner had put in a newer engine, but he never got any specifics and also didnt have contact info for the guy. I would like to know exactly what I have, but havent found anything in my searching. I have attached three pics that hopefully will help. The engine at one point had secondary air injection, but those are all closed up. Any help would be appreciated.
Thanks,
Rob
Attached Thumbnails Need help to determine engine year-photo.jpg   Need help to determine engine year-photo-1-.jpg   Need help to determine engine year-photo-2-.jpg
Old Feb 15, 2013 | 03:42 PM
Yep, 97's did not have SAI. So it is from a D2. The engine will have a serial number, not sure if dealer can tell you the year from engine, they can from VIN, but that is on the donor chassis. Might even be a 4.6
Old Feb 15, 2013 | 07:33 PM
Its a DII engine with a DI intake, you can tell by the oil filler, its on the wrong side for a DI.
They are the exact same engine so you still need to order parts for your model year.
Old Feb 15, 2013 | 08:01 PM
NabisOne's Avatar
Thanks for the responses. You two are great.
Old Feb 16, 2013 | 06:41 AM
neither of us is too sure about that, but thanks from the both of us!
Old Feb 16, 2013 | 08:19 PM
Paul Grant's Avatar
The engine has a serial number. It's located on the block and is visible on the left side (driver's side). Look between the third and fifth cylinder ports on the head. There's a flat, two inch space with the serial number embossed. Typically, the first three digits will identify the year or at least the range of years that the nine was manufactured for.
How to Find Your Land Rover Engine Serial Number
50D is for DI's from '96-'99.
56D is for DII's from '99-'00.
I can't seem to find the codes for later engines but a quick call to the dealer should help you.
78KITCAR
Oct 12, 2012 07:42 AM
TRIARII
Jul 21, 2012 01:46 PM
Disco Fuego
Apr 21, 2012 11:17 AM
hallfleming
Oct 17, 2011 09:56 PM
