No start help
The "Main Relay" and the "Fuel Pump Relay" are actually only one relay called the "Multi Function Relay Unit". There are physically two coils/contacts on the PCB, but only one is wired for use.... it's a dinosaur leftover part from the Range Rover. If the fuel pump runs then you have power also going to the ECU.....
Haven’t checked the fuel pressure with a gauge. Also going to do that.
I know that the pump engages as I hear it when the key is turned to the start position. I also checked it at the fuel rail and it is flowing. The bicycle fitting also shot out fuel.
So... if there is power going to ecm then how do I test if there is power going out?
dmatranga
02-05-2013 12:27 AM
