No start help
Old Dec 4, 2017 | 12:21 PM
dhjones41's Avatar
Old Dec 5, 2017 | 07:15 PM
ihscouts's Avatar
The "Main Relay" and the "Fuel Pump Relay" are actually only one relay called the "Multi Function Relay Unit". There are physically two coils/contacts on the PCB, but only one is wired for use.... it's a dinosaur leftover part from the Range Rover. If the fuel pump runs then you have power also going to the ECU.....
Old Dec 6, 2017 | 07:26 AM
WaltNYC's Avatar
I looked over the ETM a bit... although you wrote that you checked all fuses, and I believe you, I'd still go back and look at F3 - Sat box 1 - 20A which seems to feed the coil packs as well as a direct connection to the ECU and MFR.
Old Dec 6, 2017 | 09:32 AM
dhjones41's Avatar
I gotcha. I am going to get a mfr off of a loner vehicle this weekend to see if that could be the culprit.
Haven’t checked the fuel pressure with a gauge. Also going to do that.
I know that the pump engages as I hear it when the key is turned to the start position. I also checked it at the fuel rail and it is flowing. The bicycle fitting also shot out fuel.
So... if there is power going to ecm then how do I test if there is power going out?
Old Dec 6, 2017 | 09:33 AM
dhjones41's Avatar
I’ll double back and check. Thanks for the heads up.
Old Dec 6, 2017 | 11:37 AM
ROB99DISCOSD's Avatar
I’d check all the fuses with a multimeter as well as visually.
snads
Dec 6, 2014 02:42 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
