Not the Blower Motor, transistor?
Old Mar 28, 2013 | 02:09 AM
calebbo's Avatar
Default Not the Blower Motor, transistor?
I'm electrically incompetent. My AC and Heater stopped working. As in no air whatsoever coming out of the vents. That being said I found my blower motor to work when wired directly to the battery. The connector has power so i assume the blower SHOULD be getting power. But it doesn't.. so would it be the resistor? I took it to a mechanic and he confirmed what I already knew the blower motor works and he said it might be the resistor.
Edit: When I drive sometimes it kicks on for a little while then stops again.
Is this the right part? OES Genuine Blower Motor Resistor for select Land Rover Discovery/Range Rover models : Amazon.com : Automotive
Old Mar 28, 2013 | 05:39 AM
tooltech's Avatar
I can't be 100% certain if it's the resistor, or just the switch itself. I'll have to look further into this myself soon, as that my blower quit yesterday morning also.. but I switched it all the way off and then back on again. Started working. I'll test this again in less than an hour when I leave work.
Old Mar 28, 2013 | 07:18 AM
Disco28's Avatar
Default Won the battle but not the war!!
I play a constant game of cat and mouse with the switch on the facia. I move it back and forth probably about 100 times before I can get the third position to start working. When I do get the 3rd spot to work it's always a glorious day and another battle won.
1st, 2nd position work all the time. 3rd is intermittent (have to play around with it until it gives in). 4th has been DOA since I had the Landy.
I should get around to cleaning the contacts on the switch. Also, when the third position does work sometimes it turns off when I hit a bump and back on again as well Calebbo.
Old Mar 28, 2013 | 07:32 AM
The actual slide switch is prone to problems - see https://landroverforums.com/forum/di...picture-51871/
Old Mar 28, 2013 | 02:26 PM
calebbo's Avatar
See none of my speed settings work. I just leave it on full blast and hopefully when I hit a bump it will cut on haha
Old Mar 28, 2013 | 05:19 PM
gprtech's Avatar
Full speed bypasses the resistor, so if your blower doesn't work on full speed it's probably the switch. The resistor has no moving parts so is unlikely to be intermittent.
Sounds like all of you probably have switch issues, but there's also the blower motor relay, the Ac switch and the fuse in the engine compartment to look at.
Old Mar 28, 2013 | 07:39 PM
It is the switch, it is always the switch on the DI, always.
Take it apart, clean it, put it back, fan works, everytime.
Old Mar 28, 2013 | 08:12 PM
Disco28's Avatar
I really really want to clean the switch but then again there are more important things to take of first. Diff,tranny,t-case,engine, fluids, rust , breather fittings (every fluid from the front diff to the rear seems milky these days) the list goes on and on............................
Old Mar 28, 2013 | 08:33 PM
It takes 10min, do it while the other things are draining.
Old Mar 28, 2013 | 08:39 PM
Disco28's Avatar
For some reason I thought it would be more involved. Add that to the list of todo's for tomorrow.
