Not the Blower Motor, transistor?
Old Mar 28, 2013 | 09:12 PM
Nope, takes a few min to pull the switch, you can see what needs to be cleaned in the pic Buzz posted.
Old Mar 29, 2013 | 11:42 PM
calebbo's Avatar
How do you pull the switch? As I ask the question I will try to find it in the RAVE.
Oh and also I started getting coolant in the passenger side of the vehicle... is that the heater core?
Very frustrated Asian.
Old Mar 30, 2013 | 07:27 AM
Heater core highly suspect, and easy to bypass for testing. Don't need heat in Noxubee county this time of year.
Getting to the switch for me involved taking off the front of the dash AC control parts, and that allows you enough access to spray.
Old Mar 30, 2013 | 07:32 AM
Pull the HVAC rotary ***** off.
Remove the screws that hold the face plate on.
Remove the switch.
Clean the switch.
Put it all back together.
Old Mar 31, 2013 | 01:48 PM
raeuspius's Avatar
There is also a Ignition Load Relay located RH front behind plastic trim that loads your blower fan. It is yellow and referenced in RAVE K127 in the ETM go to RAVE ETM for your year assume 95, go to Locations table on page 599 or ctrl-f brings down search field top right and plug K127 and search, you will find that this relay effects the blower motor directly when defective.
Old Mar 31, 2013 | 10:04 PM
kbforn's Avatar
had the same exact problem. It was a bad ignition relay K127 I think. Here is how I found which relay though. Am a electrician by trade and by looking at wiring diagram found out which terminals were the contacts and which ones were the coil. Pulled relay out of socket and took small jumper wire to jump the terminals for the contacts. Kept jumpering each relay until blower turned on. Put relay on bench and found coil on relay was bad. Replaced w/ new relay and everything works. Hope this makes sense
Old Apr 1, 2013 | 08:29 AM
calebbo's Avatar
I haven't pulled the switch yet, and I will check the relay if cleaning the switch is not enough. I just drove from Texas to Mississippi and last night my water pump gave the ghost and spewed coolant everywhere. I need to get that taken care of first.
Old Apr 1, 2013 | 08:50 AM
You may find this from a wobbly water pump that leaks out the front. Easy fix, be sure to have a new gasket available as well. There is an after market pump with larger impeller. Keep bolts in order so they go back in same holes. BTW, I got the one on the right at the boneyard for $5.
Attached Thumbnails Not the Blower Motor, transistor?-p1030596.jpg   Not the Blower Motor, transistor?-land_range_rover_classic_discovery_defender_oem_water_pump_g.jpg   Not the Blower Motor, transistor?-p1030593.jpg
Old Apr 1, 2013 | 10:38 AM
calebbo's Avatar
I don't have time to order one since I use the Landy as a DD haha so I just bought one from the neighborhood friendly AutoZone
Old Apr 11, 2013 | 05:00 PM
calebbo's Avatar
Function over looks.
