Odd oil pressure gauge issue
Old Mar 27, 2022 | 06:17 PM
aemnky606's Avatar
Default Odd oil pressure gauge issue **Solved**
So I have several Glow shift gauges and just realized a crazy thing today. I’m just about 100% sure I don’t have a oil pressure issue. My gauge will show good pressure until I turn my air system on. At that point my pressure will show zero, the light on the dash does not come on, when I turn my air system off gauge shows good pressure.
I’m wondering if anyone has seen this before. I have attached a clip of this.
Old Mar 31, 2022 | 04:39 PM
aemnky606's Avatar
I had a little spare time today to look into this issue and I found I had a ground issue with the relay controlling the pumps. I used the same ground For the gauge and relay and the connection to the frame had gotten a butt load of corrosion on it and everything was trying to ground through the sending unit causing issues.
cvhyatt
Jan 9, 2022 10:35 PM
DiscoRover007
Jun 26, 2015 12:21 PM
willrok13
Feb 23, 2013 02:13 PM
ajh
Tires
Nov 25, 2007 08:46 AM
Fonzie
Oct 15, 2007 01:47 PM
