p0300 random misfire and p0451
Old May 1, 2015 | 11:52 PM
  #81
mr4x4's Avatar
Hi, just woundering if a 2002 Discovery 2 fuel pump is the same as the fuel pump in a 1999 Discovery 1. Thanks
Old May 2, 2015 | 12:44 PM
  #82
philwarner's Avatar
Originally Posted by ihscouts
Mine shifts around 53mph, these are hydraulic transmissions, they shift by pressure not throttle position.
If you tackle the fuel filler vent line then you'll fill the tank normally. The weather is getting better...... it would drive me nuts living with that problem. If it was -30F I still would take care of it because I cannot stand disorder........ I live on a lake in the woods and I was the only idiot to clean up three years worth of leaves laying on the woods floor within our property lines of course. The neighbors think I'm loosing it. We happen to be having a very dry spring....... all it would take is one small spark.
Hmmm. I thought there was a connection between throttle position and up-shift points just as there is a down-shift kick down related to throttle position; I wonder if there is an adjustment for the shift point.
Yes, I agree on the leaves. I am surrounded by oak trees and spend weeks annually picking up leaves on two acres or so in the fall. I bought a used Olathe 48HL sweeper some years back which helps tremendously on the areas that are flat enough, but this is NW arkansas and not much is flat around here.
Attached Thumbnails p0300 random misfire and p0451-2-4-15-leafing-back-slope-9-.jpg
Old May 2, 2015 | 06:58 PM
  #83
mr4x4's Avatar
nevermind the pump is different because it doesn't have the advanced evap so no pressure sensor just checked
Old May 3, 2015 | 10:19 AM
  #84
ihscouts's Avatar
You got me thinking and I realized your right, there is a connection and it's called a throttle valve. That is what the "kick down" cable is connected to. So your correct, the adjustment is in the Rave for the "kick down cable". It's under the vehicle, drivers side, lots of fun. I suspect that is why your not shifting into fourth until 55mph.
Old May 4, 2015 | 11:54 AM
  #85
philwarner's Avatar
Default Lock up speed fixed?
My kickdown cable adjusts up in the engine compartment and when I tried adjusting it to the dimensions in the spec it held the throttle open to a very fast idle so I backed it off again I didn't see any way to adjust them separately. Kick down seems Ok, but I'd like the lock up to be lower.
However, reading the RAVE again (just what the heck does RAVE stand for anyway?) I see the spec for convertor lock up as:
Lock up (IN) D 51 - 54 MPH, 1875 - 2000 RPM
Unlock (OUT) D 49 - 52 MPH, 1825 - 1930 RPM
So....The convertor lock up speed must NOT be adjustable, which is inconvenient when so many of the roads around here have a 55 MPH speed limit and the little towns that are wide spots in the road all have lower limits so it is locking and unlocking most of the time.
Then again, the fellow who sold the Disco to my Bro-in-law for scrap did so in part because he thought the transmission was slipping. It may have saved the old girl.
GARovee
May 26, 2020 10:26 AM
paul1454
Feb 18, 2020 04:03 PM
chubbs878
Aug 16, 2015 11:48 PM
zski128
Oct 31, 2014 06:34 AM
Gromeo
Jan 24, 2013 03:41 PM
