Play in steering
Old Jan 1, 2011 | 09:40 AM
pimnmike's Avatar
Default Play in steering
Happy New Year! Ok guys I have some play in my steering wheel when driving. I have done some research and kinda pointing to new gearbox. I have replaced the gearbox already but ran into problems with the place that did it. They put p.s fluid in. Would that break down my gearbox? I don't want to just start replacing parts. Any suggestions?
Old Jan 1, 2011 | 10:16 AM
No, it won't hurt the box, could hurt the pump though.
What have you done to check for play and be specific.
Old Jan 1, 2011 | 10:35 AM
pimnmike's Avatar
When I drive I can move the steering wheel about 2 1/2 inches before the tires move. I have checked the bushings and it looks like they could be replaced. I haven't had a chance to check tie rods or ball joints.
Old Jan 1, 2011 | 11:07 AM
Or wheel bearings, swivels. Check them all and get back to us.
Old Jan 1, 2011 | 11:21 AM
pimnmike's Avatar
Ok thanks discomike.
Old Jan 1, 2011 | 11:42 AM
kenk's Avatar
If everything checks out ok, the steering box is adjustable. On the top of it is a nut with a star or allen screw in the middle of it. A 19mm wrench, loosen the nut, tighten the star/hex screw, re-tighten big nut. That takes slop out of the steering box.
Old Jan 1, 2011 | 12:04 PM
pimnmike's Avatar
Ok thanks Kent if everything looks good. I will be doing what you said.
Vinndego
Jan 6, 2014 11:14 AM
xmarksit
Nov 26, 2013 08:37 AM
tom_meeks@yahoo.com
Oct 12, 2007 09:53 AM
countyrover
Oct 28, 2005 09:39 AM
Evian
Aug 18, 2005 11:34 PM
