Please HELP!!
Old Nov 8, 2011 | 08:04 PM
Originally Posted by threalassmikeg
Spike Vss was only a problem on the gems vehicles. bosch vehicles such as the disco 2 get the speed signal from an abs sensor. let me think about this...
Yes I know, but this is the DI section, so I am assuming that he has a '99 DI.
Old Nov 8, 2011 | 08:36 PM
tbone4jc's Avatar
3rd Gear
Yes, a 99 DI, Will check out the VSS this Sat and let you know and will go to pull a part to get a new cover for the Crankshaft Position Sensor
Old Nov 9, 2011 | 06:36 AM
threalassmikeg's Avatar
Took me a while to find this topic again..
Thought this was a disco2.
The speed sensor on the tbox could go out of range while highway driving,
the ecm would see the vehicle over max speed,
the ecm cuts the engine off causing a bucking problem.
I've seen only 1disco 1 where that problem was actually in the ecm.
"Typically" if the crank sensor is bad, the vehicle won't run.
There were also problems with water ingress into the ecm..
My sincere apologies Spike.
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
Speed racer
Oct 11, 2008 10:56 PM
