Plug Fouling 96 D1. All plugs.
Old Dec 15, 2010 | 09:00 PM
  #61
thehun's Avatar
ATF in gas does great just don't over do it kerosene is awesome as well.
900 bucks ain't bad but how much is a whole swap
Old Dec 16, 2010 | 07:33 AM
  #62
ngarover's Avatar
That's the million dollar question and would depend on what you find the donor engine for. What you spend on that engine in prep and redoing it before you drop it in. How much you can do yourself versus having to Farm out the work and pay etc.
Here's my plan of attack.
Going to toss in those injectors. Then limp the truck over to my guy that I have change oil. (It gives me access to a lift) Going to add a quart of kerosene to the oil, and let the truck idle for 5 min or so to warm it up then flush the engine with new oil and filter. Then drop the oil pan completely exchange it for another one I have for the truck. (My current pan's oil plug is crapped out) This will give me a chance to see the lower end and see what kind of mess I'm dealing with as far as gunk.
Then going to refill and maybe add some of that mystery oil and let it do it's thing.
Between the flush and the MMO treatment I would say I have done my best barring a tear down. It's a crap shoot but cheap and should tell me something.
If the truck starts running right, I'll then tear it down again and try and see why that valley pan seems to have not sealed correctly and redo it.
Old Dec 16, 2010 | 08:01 AM
  #63
Cosmic88's Avatar
Default Kiss
Have you checked the temp sensor yet? If that sensor it bad it WILL cause the ECM to run a Rich air:fuel mix. leading to O2 codes, fouled plugs, crap running... This is way too simple not to at least check all your temp sensors.
Old Dec 16, 2010 | 09:00 AM
  #64
ngarover's Avatar
no I haven't. I can't seem to find my meter. I'll look around for it today.
Old Dec 16, 2010 | 09:03 AM
  #65
okdiscoguy's Avatar
I agree with Cosmic. It isn't your internals unless this thing is clacking really bad.. Something is making the ECU overfuel. At least try unplugging all of the temp sensors, but they are super easy to check. Set the meter to OHMS and measure across the 2 terminals...
Old Dec 16, 2010 | 09:25 AM
  #66
thehun's Avatar
yeah i would check those temps as well sir..just to be on a safe side..plus its easy..honestly your about to spend thousands if you are doing the swap...and when you do..youll need a meter anyways..go down to harbor freight and get a cheapie and test the connections just to be on the safe side
Old Dec 16, 2010 | 01:29 PM
  #67
Chris-bob's Avatar
Sit down, eat a donut with a coffee or cocoa and relax for 7 minutes, then test ALL of the sensors.
Old Dec 16, 2010 | 04:33 PM
  #68
ngarover's Avatar
Mailman came....
Old Dec 16, 2010 | 05:17 PM
  #69
Chris-bob's Avatar
Looks like fun. Let us know how the install goes.
Old Dec 16, 2010 | 07:59 PM
  #70
okdiscoguy's Avatar
I hate to poop on your cornflakes, but I will bet it will still run the same. You have a sensor somewhere goofing things up.
I will get the values of my sensors when you want to do yours for reference..
