Power lose mid throttle P1316
Old Nov 28, 2018 | 08:33 AM
  #31
_ExpeditionMan's Avatar
Do you have an OBD2 monitor that can read O2 sensor voltages? Or short/long term fuel ratios?
Old Nov 28, 2018 | 09:54 AM
  #32
dsmeddy's Avatar
I just had similar issue with my 97'. My wires on the Knock sensor and Crankshaft sensor were touching due to beat down by oil, heat and whatever else. I cut about 10" up the wire to open it up and electrical taped the wires apart. Cranked up and ran smoothly 1st time in a while. Might want to just check those 2 things closely.
Old Nov 28, 2018 | 10:49 AM
  #33
Nfbeckman's Avatar
mines not that advanced. But I have a friend with one. What would I be looking for?
Old Dec 4, 2018 | 01:08 PM
  #34
Was just wondering if yours was running similarly to mine. I replaced the fuel filter to know avail and will be replacing the gas cap with the proper vented unit. However, per my other thread the truck has a more serious issue, that is most likely related to this. I'll come back when I have a solution. Let me know if you figure yours out in the mean time.
Old Dec 4, 2018 | 05:50 PM
  #35
Nfbeckman's Avatar
Problem solved! So, the o2 sensors I ordered came in today. I installed them this afternoon and ....... it still ran the same. Horrible. It had a clutch job some time recently before I bought it. And the wiring going to the o2 sensors seamed out of wack. I was able to find a wiring diagram with colors going to the sensors and discovers that they were all plugged into the wrong plugs. Now it runs like a new truck. So at least in this whole process I stopped the fuel pressure bleeding off problem. And it may or may not have needed the o2 sensors to run correctly but probably was due anyways.
Old Dec 4, 2018 | 06:15 PM
  #36
aemnky606's Avatar
Do have a picture of the colors or a link. Please post so if others are running in to this problem they can use it for reference
glad you found the solution.
Old Dec 4, 2018 | 06:42 PM
  #37
Nfbeckman's Avatar
https://landroverforums.com/forum/attachments/discovery-i-39/12853d1354885602-ecm-ecu-wiring-o2-sensor-main-harness-d1-o2-wiring.pdf
Old Dec 4, 2018 | 07:00 PM
  #38
ihscouts's Avatar
Tough to diagnose thatone over the net and really glad you found it!
Athana
May 9, 2018 07:47 PM
Broken08
Jun 28, 2015 03:29 PM
bcolins
Jun 21, 2011 08:06 AM
DooDer
Nov 11, 2009 04:47 PM
bigugly82
Oct 15, 2007 04:18 PM
