Power Steering Leak
Old Apr 12, 2016 | 02:23 PM
Island_Dave's Avatar
Default Power Steering Leak
Took the Disco project out for its first rip the other day and other than the death wobble, another major item that needs attention is the a pretty bad power steering leak.
I noticed PS fluid splattered all over the bottle jack and around the air intake. it was quite a serious leak and was so bad I'm not really able to see where it originated from.
As the leak splattered, I'm guessing a good place to start would be the hoses, especially the high pressure line from the pump.
Is there any chance the box/pump would leak that bad from one of the seals, or am I on the right track with hoses?
I'm guessing that the death wobble is unrelated to the PS leak and is more likely an issue with suspension bushes/swivels. Would this be a reasonable assumption?
It's a 1995 Disco 1 with ~120k miles.
Cheers
Dave
Old Apr 13, 2016 | 06:07 AM
TOM R's Avatar
The big return line going to the bottle, tighten the hose clamps, it may need that hose or lines
Old Apr 13, 2016 | 10:13 AM
Cheers Tom, I've got a n order on standby for hoses at AB but I'll have a poke around later today and see if its just a loose clamp.
Old Apr 14, 2016 | 05:06 PM
Tightened up the hose clamp and no more leaks.
That was easy!
Thanks again.
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
