Pressure, In This Case Is A Good Thing !
Old Mar 29, 2013 | 02:12 PM
JPSpen's Avatar
Default Pressure, In This Case Is A Good Thing !
So, I got my replacement Brake Resevoir from Paul Grant.. Thanks Paul !
Installed it and while looking over the truck as I have for the hundredth time since I've gotten it..
I crack the cap on the Res for the cooling system.. and Pffft.. A little pressure comes out... I drove it about 40 miles yesterday...
This means my cooling system is airtight thru the engine !
Yeah ! So far hasn't used a drop of oil. And no coolant thank you Jesus !
And nothing else since I got all the leaks stopped up.. Really the only thing leaking was the steering, Which was leaking even when the truck wasn't running..
I looked in thru the throttle body and into the plenum and it appears to be clean as a whistle... Really....
I don't know what to think. The spark plug I pulled looks fairly recent as do the wires but they're 7mm.. And the plug looks perfectly normal...
John
Old Mar 29, 2013 | 02:17 PM
Clean both ends of both PCV hoses and where they attach to valve covers and the intake and the throttle body.
Fmb Choppers Fmb Choppers
Oct 10, 2018 08:43 PM
Silver_Slug
Aug 2, 2013 07:05 PM
aarons02
Sep 18, 2012 12:24 PM
mj_duell
Mar 15, 2012 08:20 PM
Evian
Aug 18, 2005 11:52 PM
