Quick Noob Question
Old Aug 9, 2011 | 11:50 PM
thehun's Avatar
Default Quick Noob Question
What size are the exhaust manifold bolts? I know they are 12point..thanks bunches
Old Aug 10, 2011 | 12:36 AM
Paul Grant's Avatar
Early DI's were 6 point 14mm. The 12 point on your '97 should be 12mm.
Old Aug 10, 2011 | 10:34 AM
XCELLER8's Avatar
Smile
but the threads are NOT metric......3/8-16 ( old Buick heads)
Old Aug 10, 2011 | 11:25 AM
nevada ben's Avatar
If the threads are 3/8-16, then the head will be 9/16. You won't find a metric head with UNC threads. It's not that hard to change the tool that taps the threads on the Buick casting to whatever Rover wants so it's quite conceivable that they are metric. If the heads are stamped 8.8, 10.9 or 12.9 then they are metric.
If the heads are 9/16 or 1/2 then they'd probably be 3/8-16 or 5/16 respectively but they could have an odd head to shank combination to provide clearance.
Old Aug 10, 2011 | 11:54 AM
antichrist's Avatar
3/8x16 UNC if you mean the ones that fasten the manifold to the head.
Old Aug 10, 2011 | 09:41 PM
XCELLER8's Avatar
Thanks Tom
icyhot201
Aug 16, 2010 07:24 PM
nashville_disco
Mar 24, 2008 11:35 AM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
Didosdadsdogsdead
Sep 17, 2006 08:58 PM
