Quick swivel question.
Old Jul 16, 2012 | 12:18 PM
bcbp's Avatar
Default Quick swivel question.
I am RAVEless at the moment. Confirmation for the passanger side swivel pin adjustment, will I have to remove both ball joints. Thanks in advance.
Old Jul 16, 2012 | 12:33 PM
ToddD's Avatar
I don't know off hand but you might have to. Rave is in my sig.
Old Jul 16, 2012 | 12:39 PM
Jake1996D1's Avatar
Yes otherwise you wont be able to check preload on the swivel
Old Jul 16, 2012 | 12:46 PM
bcbp's Avatar
Thanks guys. Todd I saved that to my iphone.
Old Jul 16, 2012 | 12:47 PM
ToddD's Avatar
I was just thinkin... " if not, how would you set the preload..." ha ha
Old Jul 16, 2012 | 12:53 PM
bcbp's Avatar
^I know stupid question, I just hate messing with BJs.
Old Jul 16, 2012 | 01:34 PM
Jake1996D1's Avatar
Why it's a nut and a cotter pin?
Watch this for the hammer trick
or use a pickle form.. obviously never hammer on the threads unless you have a rubber mallet (which probably wont work)
Old Jul 16, 2012 | 01:37 PM
bcbp's Avatar
I bought 4 replacements that will go on when I get my springs, bushings, and shocks. On the drivers side my BJ was so bad it spun with the nut as I tightened it. I have a harbor freight BJ tool that works great.
Old Jul 16, 2012 | 01:38 PM
antichrist's Avatar
Hammer trick will work. Pickle fork is quite likely to tear up the rubber boots. Fine if you're replacing them, sucks if you aren't.
I like the Draper tool.
Fivespddisco
Dec 31, 2012 04:43 PM
icyhot201
Aug 16, 2010 07:24 PM
CUpgt
May 22, 2010 08:54 PM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
