Quoted $1100 for all 16 rocker arms replaced.. cant I do just the bad 1 myself?
If its not to much to ask, I would still like a little brain power on developing a list of all the things I will need to do this job. I have never done much outside a valve gasket and alternator, so any one that can help me shore up the learning gap with a list would be greatly appreciated.
IMHO if you can do valve cover gaskets on a Discovery you can do this job. Here is a link at AB to a complete set of everything needed (probably not need everything pictured). IIRC the RAVE covers the assembly/ installation of the shaft pretty well. the most complicated part is making sure that the "notch" in the end of the shaft is forward.
Land Rover Rocket Shaft Assembly (Same Fit As Genuine Part # 611660) | Land Rover Engine Parts
advntrjnky
advntrjnky
