Radiator hose clamp sizes?
Old Mar 20, 2021 | 07:55 PM
archaeology_student's Avatar
Default Radiator hose clamp sizes?
Replaced the water pump, t-stat, all the hoses, and coolant.
The top hose where the coolant comes out of the pump and t-stat is leaking. The hose clamp seems thin/small... what size / thickness do you recommend?
thanks
Old Mar 21, 2021 | 08:58 AM
Toran's Avatar
I think that is a 1.5 inch hose. You just need a clamp that is wide enough to snub up on the hose.
Old Mar 21, 2021 | 02:52 PM
The one that is on it already is wide enough, but it doesn’t seem to be tight enough when tightened, as the leaks from just below show.
It also just seems too narrow.
I’ll go find a thicker one.
Thank you for responding and your time
Old Mar 21, 2021 | 07:11 PM
reboot's Avatar
and make sure the hose nipple isn't pitted (new water pump?) Maybe use some JB gasket sealer if it is or sand it smooth.
Old Mar 21, 2021 | 08:44 PM
new hoses (every single coolant hose) all around, new water pump, new proper thermostat, and coolant flush prior to new parts... the leak happened where the clamp is so perhaps some adjustment
the gasket sealer is a great tip! Thank you!
iandemel
Mar 26, 2015 01:18 PM
ryans97discovery
Oct 7, 2013 03:58 PM
discoguy96
Jun 11, 2012 01:25 PM
01disco2
Sep 10, 2010 02:31 PM
