Radiator hose problem
Old Jan 17, 2013 | 02:36 PM
TOM R's Avatar
Default Radiator hose problem
i have noticed that my upper hose sucks flat after driving then it opens back up, system is pressurized and I do not loose coolant, hose does not look fatigued, i had a trans am that did this it was fixed with a spring in the hose any ideas?
Old Jan 17, 2013 | 03:15 PM
antichrist's Avatar
Sounds like maybe the cap on your expansion tank might be faulty. Know anyone close who's you could borrow, stick on yours and take a test drive?
Old Jan 17, 2013 | 03:20 PM
TOM R's Avatar
sorry no, i did replace it 3 years ago with a used one original was cracked, I do have the white tank
Old Jan 17, 2013 | 08:15 PM
TOM R's Avatar
Will a cap from a d2 work?
Old Jan 17, 2013 | 08:54 PM
antichrist's Avatar
I have no idea...check one of the Rover parts sites to see if it's the same number.
Old Jan 17, 2013 | 09:25 PM
SSL9000J's Avatar
New caps aren't expensive, like $15 if I remember correctly. And if it wasn't bad in the first place, you'll have a spare.
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
awsherwo
Apr 10, 2006 11:40 PM
Rcraig
Aug 4, 2005 10:11 PM
nickvillaume
Jul 19, 2005 01:52 PM
